Moto G Edge 2026 & VoLTE
  • September 19, 2026
  • 83 views
Just ordered this phone for a second user and noticed it does not come with VoLTE for any plan.
2 questions:
Will they even notice?
Any idea if Koodo plans to enable VoLTE support in the future?
In a rural area (Gulf Islands, BC) with only a Rogers tower so far, but rumour has it, co-location in the works. The days of constant usa roaming are gone, thankfully :-)
Best answer by Dinh
Did you order from Koodo/Telus? if so, the device is VoLTE compatible already.
Without VoLTE the phone will still use LTE for data, but calls fall back to the 3G network. Day to day your second user probably won't notice much, as long as calls work. Where it matters is the 3G shutdown that starts March 1, 2027. At that point calling on a non certified device goes away. There is also a 3G usage price increase that can show up on the bill for devices the network doesn't read as 4G.
Koodo typically has to certify a model before provisioning VoLTE on the device, and there's no way to know in advance which models get added. I would run the IMEI through the compatibility checker to see how the network actually reads it https://www.telus.com/en/support/article/how-to-use-volte
Its an unfortunate thing that Telus seems to not commit to allowing any device to provision with VoLTE. Sometimes people report non Canadian devices get it, sometimes people report its gone again. It really bothers me personally, especially since they started charging $3 a month for 3G voice use and 3G networks are being shut down soon. It will effectively block non - Canadian model phones entirely if they don't remove the whitelist. Public Mobile has been reported to keep a More strict list, but I don't see much for Koodo and how its different.
Let us know what the comparability checker says for your phone.
  • September 20, 2026
The phone is from online Koodo moto edge - 2026 | Phone Plans | Koodo Mobile.
Replacing an old A70 which does have  VoLTE activated.
My concern was after I choose a plan, the popup included “Removed VoLTE access”.
Perhaps I just need to enable it, once the phone is delivered and activated?
Thanks gang
​@Jorgy
Just to double check, did you get the “Removed VoLTE access” after ordering the new phone and selected a new plan?
is this for the line ending in *09?
Correct.
Online purchase. Choose a new phone, then a new plan at same time, same order.
(old plan not eligible with new phone)
I just repeated but without proceeding to purchase(cleared order after)
It’s probably just me be confused :-)
​@Jorgy
Thank you for sharing!
VoLTE should normally be enabled by default on eligible devices. Please let us know once you receive the phone in case of issues with the VoLTE benefits.
