Lost Phone
  • Oct 12, 2026 2:45 PM UTC
  • 3 replies
  • 56 views
I have lost my phone in Europe and am currently waiting and hoping it will be returned!
In the meantime, I have an iPhone 8 I would like to use instead. I don’t believe it is eSIM-compatible, though, and I need a physical SIM.
Will Koodo provide me a new physical SIM?
Any other recommendations?
Best answer by Flo Koodo
HI ​@Alexandra Phillips
We are sorry to hear that you lost your phone!
Just to double check, are you currently in Europe or in Canada?
If you are in Canada, you should be able to get a physical sim replacement in a store and perform a sim swap in self serve using the steps here https://www.koodomobile.com/en/help/koodo-sim-support
  • Oct 12, 2026 2:54 PM UTC
Hi Flo! I am back in Canada. Once I (hopefully) get my old phone back, I can then convert the physical SIM back to an e-SIM?
  • Oct 12, 2026 3:16 PM UTC
​@Alexandra Phillips Conversion of the psim to esim should be possible, is the phone that you hoping to get back compatibile with both psim and esim?
