Is Motorola Edge 2023 esim compatible?
  • Mar 31, 2024 5:44 PM UTC
  • 584 views
I have seen a few different answers online regarding Motorola Edge 2023 esim compatibility. Some say yes and some say no. Does anyone actually know? I will be travelling Europe this summer and I need an esim compatible phone. Thanks!!!
Best answer by Allan M
According to here, under “what you’ll need” it does:
https://www.koodomobile.com/en/help/esim-and-esim-vouchers
Allan M
  • Mar 31, 2024 5:59 PM UTC
  • Mar 31, 2024 7:54 PM UTC
Yes I saw that . But I have also read that the Canadian Motorola Edge 2023 does not support esim?
  • Mar 31, 2024 8:15 PM UTC
Where did you see esim wasn't supported on the device? Was it from Motorola?
  • Mar 31, 2024 8:42 PM UTC
Hmmm I might have answered my own question. Upon further digging it looks like the Motorola Edge Plus does not support esim in Canada ( as per the Motorola forum) However, it looks Koodo carries the Motorola Edge (no plus).
John Zarubiak
When I was checking out Fido for bring your own phone I put in my Edge 23 and it said E Sim compatible??
