international 11b1
  • May 3, 2025 1:52 PM UTC
  • 7 replies
  • 185 views
I just subscribed to international minutes 1000 per month on my Koodo plan and have run into an issue on the first call - I tried a UK landline number and get the 11b1 message. The minutes were active from yesterday and the landline is functional for other other users. Any ideas what's going on there? Thanks
Best answer by Matthew_F
Oh but 011 44 works! I just got through - weird, I never had to dial that before when using Skype but that seems to have worked - thanks for putting me on the right track! Issue resolved ✅
  • May 3, 2025 2:32 PM UTC
Hi ​@Matthew_F
Have you tried making calls to a different intenational number?
Just to double check, you are not getting this message when you call Canadian numbers?
  • Rockstar
  • May 3, 2025 2:42 PM UTC
Hi thanks for helping … it's just UK numbers that have the issue but Canadian numbers are OK
  • May 3, 2025 2:54 PM UTC
​@Matthew_F
Thanks for confirming!
We have just made a refresh of the international add-on, can you please restart your phone and then try making an international call?
  • Rockstar
  • May 3, 2025 4:35 PM UTC
Hi / unfortunately, that didn't work and I get the same error message
  • May 3, 2025 4:47 PM UTC
Got it!
Just to double check, are you dialing 011 44 in front of the UK landline phone number?
  • Rockstar
  • May 3, 2025 5:10 PM UTC
Im dialling 0044 for the Uk but the 001 just gives me the error :(
  • Rockstar
  • May 3, 2025 5:14 PM UTC
