Incorrect Outbound Call Display
  • Oct 7, 2025 10:17 PM UTC
  • 149 views
For starters I have never purchased outbound call display name.
People inform me that the name “growth marketing” shows up when I call them.
I need this to stop as I use my phone for work.
thanks in advance
Best answer by Georgia Koodo
​@Davey22bighorn Here’s a direct link https://hiyahelp.zendesk.com/hc/en-us/p/request_hub just select ‘Remove incorrect name shown for a call’ and fill out the form.
  • Oct 7, 2025 10:42 PM UTC
Hi ​@Davey22bighorn
Just to double check, was this always the case for this name to be displayed or it started recently?
  • Oct 7, 2025 11:00 PM UTC
Is this a new phone number?  Call Display names are usually from Hiya’s data base.
When you login to your self serve and check your add-ons do you have the outbound name display add-on there?
https://www.koodomobile.com/en/help/outbound-calling-name-display-for-mobile-devices?srsltid=AfmBOor4X_bceHqAiMKF5T3oiV4D2PMOz_04JI5XnDQwF4PJcRqOhmZa
Timo Tuokkola
You can update your phone number information with Hiya through this page: https://en-ca.hiya.com/samsung/products-smart-call
  • Oct 7, 2025 11:39 PM UTC
your a stud buddy keep it tight big horn out thx.
