Incoming caller ID connection problem or invalid MMI code
  • Nov 29, 2026 3:25 AM UTC
  • 37 views
JoanneM
Phone: Google Pixel 10 Pro
All of my calls are coming in as Private, so I can’t tell who’s calling. I spoke with Google and nothing they told me to try worked. The last thing she had me try was *#30#, and I got the following message:
She told me to get in touch with Koodo, and that you  just need to refresh Incoming Caller ID on your line.
I guess I need someone to do that for me. But do I have to pay to get this done, if I have to talk to a support person?
  • Nov 29, 2026 3:29 AM UTC
Have you tried following the steps in the video?
What about inserting your SIM card into another device to see if it is experiencing the same issue?
If it is still showing the problem, it is possible that your Caller ID function has been disabled. You will need to schedule a callback through Koodo Assist and speak with a rep to provision your settings. https://Koo.do/Chat
JoanneM
  • Ambassador
  • Nov 29, 2026 4:37 AM UTC
I don’t have another device to put it in, but I will follow the link you gave. Thanks!
Joanne
JoanneM
  • Ambassador
  • Nov 30, 2026 12:36 AM UTC
I booted into safe mode.
I used the *#30# and got the following error message:
Carrier Message
Incoming Caller ID
Connection problem or invalid MMI code
If I go to Calling Accounts - Koodo - Settings - Additional Settings, I get this message:
Call settings error
Unexpected response from network.
I was online with Google most of yesterday, and then with Koodo Assist most of today. They are supposed to call me tomorrow. But is that going to cost me? I am pretty sure I have my settings correct, but not completely sure.
I am using Wi-Fi Calling, because there is basically no phone service where I live. I have the phone set up to use wi-fi calling. And it worked fine until about 2 months ago, then all of a sudden, it didn’t. I guess I’ll wait till I hear back tomorrow.
I’m just so frustrated!
  • Nov 30, 2026 1:53 AM UTC
Carrier Message
Incoming Caller ID
Call settings error
Caller ID (Call Display+) is free for all Koodo customers, so getting it working on your line shouldn't cost you anything. I'm not aware of any charge for a callback with a rep about it either.
Since the Additional settings menu gives "Unexpected response from network" and safe mode didn't change anything, it's worth having the rep check how caller ID is set up on your line. When they call tomorrow, mention both error messages and that you're on Wi-Fi calling because there's basically no signal where you live.
Just to confirm, did anything change around 2 months ago when it stopped, like a new phone, a SIM or eSIM change, or a plan change? As well, did you buy your Pixel 10 Pro in Canada?
JoanneM
  • Ambassador
  • Nov 30, 2026 2:13 AM UTC
Thanks for your reply. No. nothing has changed in my Koodo account. No new phone or SIM. Yes I bought the phone on Amazon Canada. That was in 2025. There was an update to the phone in October, and I wondered if that could have been the problem, somehow. But I mentioned that to the Google person, and they didn’t think that would be the problem.
