I transferred from Rogers to Koodos over 48 hours ago and my number still hasn’t transferred.
  • Aug 18, 2021 11:43 PM UTC
  • 3 replies
  • 630 views
Cameryn Rybansky
I transferred from Rogers to Koodos over 48 hours ago and my number still hasn’t transferred. My iPhone will not verify my phone number and on Koodo it still says my number is in progress what do I do?
Best answer by MilkyWay
Did you check your Self-Serve account? Does it say that your number has successfully transferred to Koodo? If not, I highly suggest you to schedule a callback through Koodo Assist and ask them to send you over to someone on the porting team. https://Koo.do/Chat
I would also contact someone from Rogers. It is possible there is a port block set on your account, preventing you from porting over to Koodo. You can give them a call at 1-877-327-8503.
Allan M
  • Aug 19, 2021 12:09 AM UTC
When you submitted the request you should've gotten a text on your rogers sim card that there was a request to port your number and you have to reply yes to that. Did you do that?
  • Aug 19, 2021 2:36 AM UTC
If you haven’t I’d recommend contacting Rogers to see if everything is ok on their end for the transfer.
  • Aug 19, 2021 4:25 AM UTC
