I broke my phone and I need one for work HELP!
  • Jul 25, 2022 10:14 PM UTC
  • 3 replies
  • 127 views
Is  there anway I can talk to someone online?? I dont have a phone and I need one for work and right now I have no way of going into a store as I am working constantly and when I am done work everything is closed!!! I am open to any ideas thank you!
Allan M
  • Jul 25, 2022 10:28 PM UTC
You should be able to order one online. Is there anything you need help with or that’s giving you trouble when you try? Online orders will take a few days to get to you.
Are there any other locations that are open later? Places like Best Buy and Walmart typically have wireless centers that sell Koodo that may be open later than a typical Koodo store. As well a lot of Telus stores now sell Koodo as well.
Sophia
  • Jul 26, 2022 12:05 AM UTC
And if you are in real pinch, buy a prepaid phone from a store like 7-11 - they should be open 24/7. Throw away (or give away) the SIM card that comes with it and use your Koodo one.
  • Jul 26, 2022 11:58 AM UTC
You can also buy used off of FB MArketplace, Kijiji, or other options if you don’t plan to use a tab.
