How to pre-emptively avoid roaming fees?
  • May 14, 2023 11:50 PM UTC
  • 2 replies
  • 170 views
I want to preemtively avoid roaming fees, I am travelling to a part of Ontario (Pelee Island) that is close to the American border, last time I was at this location the phone thought it was in Ohio. What can I do?
Best answer by Sophia
Make sure that roaming is disabled on your phone, and to be on the safe side connect to Koodo's network manually. You'll need to do this any time you reboot your phone.
Safe travels 😄
Sophia
  • May 14, 2023 11:51 PM UTC
Safe travels 😄
  • May 16, 2023 12:08 AM UTC
Thank you I will try this
