how to fix a blocked number
  • Sep 23, 2022 2:59 PM UTC
  • 8 replies
  • 512 views
I have one phone number that I have never blocked but when they call it goes right to my VM. In my recent calls, the number shows up blocked but I have never blocked it. How do I fix it?
Boa_Guy Koodo
Hi there @Skittles914 !   You might have blocked it by accident.  Here is a helpful article. ;)
  • Sep 23, 2022 3:06 PM UTC
I have never blocked him. He's in my contact list and when I click to see if it's blocked, it shows that it is not blocked. I've called Koodo about this before. They got me to do a reset on saved passwords. That fixed it for a little while but now it's happening again. It's only that one number too
Boa_Guy Koodo
@Skittles914  Is the issue with the number ending in 0303?
  • Sep 25, 2022 4:03 PM UTC
That's my number but the number that keeps getting blocked is in my contact list
  • Sep 25, 2022 4:05 PM UTC
Which device are you currently using?
  • Sep 25, 2022 4:07 PM UTC
Samsung galaxy A52
  • Sep 25, 2022 4:11 PM UTC
Samsung galaxy A52
There are two ways to unblock a number:
  • Step 1. Navigate to and open the Contacts app, and then tap the contact you wish to unblock.
  • Step 2. Tap More options (three dots), and then tap Unblock contact.
  • Step 3. Alternatively, you can navigate to and open the Phone app. Tap More options (the three vertical dots), and then tap Settings.
  • Step 4. Tap Block numbers, and then tap the Delete icon to remove the corresponding phone number from your Block list.
Do you have ‘hiya’ or ‘smart call app’ on your phone? Try to turn off spam protection in their settings to see if the call issue can be fixed.
