How to control voicemail transcription
  • Oct 30, 2024 8:01 PM UTC
  • 2 replies
  • 196 views
I recently migrated from my dying iPhone SE 1st generation to a new 3rd generation counterpart.  I don't recall setting up voicemail transcription, but I was surprised to find that this is how my voicemail is now coming in.  I found this page about that feature: : https://www.notta.ai/en/blog/voicemail-transcription-iphone.  It says the feature is controlled through my carrier.  Can I enable/disable voicemail transcription at whim?
Best answer by Dennis
Sounds like you have Apple Live voicemail enabled.  You will have to turn that on in your Iphone’s settings
https://www.koodomobile.com/en/help/voicemail
  • Oct 30, 2024 8:18 PM UTC
  • Leader
  • Oct 30, 2024 8:55 PM UTC
Thanks, Dennis.  That’s exactly the hint I needed (though I actually wanted to know how to turn it off if I don’t get used to it).  In iOS 18.01, it is Settings → Apps → Phone → Live Voicemail.
