How can I check when my phone contract ends?
  • July 25, 2026
  • 106 views
How can I check how much time is left on my contract?
Best answer by Dinh
On Koodo there isn't a fixed contract term the way the old carriers used to do it — the plan itself is month-to-month. What you may still have is a Tab balance (if you got a phone on the Tab) and your Customer Service Agreement (CSA), which lays out your terms.
You can check both in Self Serve:
- Tab balance — the Koodo Tab page shows how much is left to pay off: https://www.koodomobile.com/en/help/the-koodo-tab-page-in-self-serve
- Your agreement details are in your CSA, which you can view and download here: https://www.koodomobile.com/en/help/viewing-and-downloading-your-customer-service-agreements-csa
let me know whether you're after the Tab balance or the agreement terms.
  • July 25, 2026
You can check on your Self-Serve account. It will show you the remaining Tab balance and the number of months remaining. https://www.koodomobile.com/en/help/everything-you-need-to-know-about-tab
  • July 25, 2026
  • Advisor
  • July 26, 2026
Thank you for your response. However, I'm not sure how to interpret the information shown in this image.
The Tab Bonus Balance shows a negative amount. What does that negative balance represent?
Does it need to reach $0 before I can switch to another carrier?
Thank you
  • Advisor
  • July 26, 2026
Thank you for your response. I found the information I was looking for.
  • July 26, 2026
Thank you
The "negative" Tab Bonus balance means it is a credit. You don’t have to pay it if you stay with Koodo. You would only have to pay that amount if you cancel or move your phone line to another carrier. Each month, that amount will be reduced by $43.25. So, 3 months from now, the balance will become $0.
Just a note, you can switch carrier at any time, all you have to do is to pay the remaining Tab balance (if you have) and Tab bonus.
Hope it helps.
