Extracting text messages from ZTE Cymbal 2 flip phone for Legal Case
  • Sep 18, 2024 6:58 PM UTC
  • 7 replies
  • 474 views
Bryan and Kylie
I’m looking for guidance on how to extract important text messages from my ZTE Cymbal 2 flip phone. These texts are crucial for an ongoing legal case, but the device is not a smartphone, and traditional methods like Google Drive aren’t available. I’ve already contacted ZTE without success. Can anyone offer advice or tools that might help with this? Your support would be greatly appreciated!
  • Sep 18, 2024 7:19 PM UTC
Have you reviewed the manual?  Im not sure if it gives any strategies in there
https://www.luckymobile.ca/Web/pdfs/ZTE-Cymbal-2-UserGuide-EN.pdf
Also you may be able to plug in the USB cable from the phone to a computer and you may be able to find a folder for text messages.  It will take some exploring and I’m not sure if the file that holds the text will be in a easily readable format.
As a last resort you can take a video/photos of the text messages with another phone.
Bryan and Kylie
I looked through the phone and couldn’t find a folder for texts. Plugged into pc, same thing. No folder. I emailed ZTE with no success, waiting on a reply from Koodo and MOBILEdit. Tried Reddit, waiting for a reply. At this point it seems my only option is to go through the hundreds of texts and manually copy them. I’m one for really tedious work, but this flip phone is finicky some times and will jump to the most recent text. I got a flip phone because “nostalgia” and boy am I kicking myself now.
Bryan and Kylie
I forgot to address your original question about checking their guide. I checked it before but will check again. Maybe I overlooked something.
Bryan and Kylie
Went through the guide using the Find operation. “Extract” offered nothing. “Text” just told me about texting.. etc.
  • Sep 18, 2024 10:44 PM UTC
Support for flip phones these days are very limited.
In the past there were computer apps (official and developed by users) that could extra this kind of phone info. But those are not likely not available since flip phones are just not popular enough. I couldn't even name the most popular flip phone (dumb phone) today
  • Sep 18, 2024 10:49 PM UTC
I assume this is you?
Bryan and Kylie
It is. I ended up manually copying them myself. Took  a good 3.5 hours. This thread can be closed/locked now. I appreciate you replying, Dennis. Thank you for your help
