Expert Messaging Issues
  • June 30, 2026
  • 22 replies
  • 149 views
Let's get you back to the conversation
Just need a quick refresh to get your conversation back. Please check your internet connection, or try again in a few minutes.
Having this issue when trying to connect in expert messaging. Tried multiple devices, networks, browsers and still that same isuse.
  • June 30, 2026
Have you tried private or incognito tab of a browser?
Can you let us know what you need help with? Maybe we can assist you here.
  • Rockstar
  • June 30, 2026
Correct, I tried incognito, different IP source, different devices. It was in regards to a conversation I was having yesterday with a rep for a new plan and wanted to continue that.
  • June 30, 2026
Hi ​@katev8103
We have looked into it and we can see that the expert messaging team responded this morning. Just to double check, did you get any notification today regarding the response?
  • Rockstar
  • June 30, 2026
Hi ​@katev8103
Hi Flo,
I tried to load the expert messaging from the help page and had issues and did not see the message chain.
  • June 30, 2026
@katev8103
Got it!
Do you have an active VPN by any chance?
  • Rockstar
  • June 30, 2026
Is there a specialized link you could private message me.
  • Rockstar
  • June 30, 2026
@katev8103
Got it!
No, I am not using a VPN.
  • Rockstar
  • June 30, 2026
I am getting a
403 Forbidden error when checking the connection element it tries to initialized to the https://participant.connect.ca-central-1.amazonaws.com/participant/connection link.
  • Rockstar
  • June 30, 2026
Can I get some priority on this from the Koodo team
  • June 30, 2026
Hi ​@brice
Will you please provide more details about your inquiry?
@katev8103
Unfortunately, we are unable to resend a link to the Expert Messaging team chat that you had, however in case you are still unable to return to the chat, we recommend initiating a new interaction with the Expert Messaging team through the virtual assist, as they should be able to access the chat history and further assist.
Let us know how it goes!
  • Rockstar
  • June 30, 2026
@Flo Koodo
Were you able to investigate my error. It was not able to initiate a new expert messaging team conversation and I provided signficiant detail about the issue.
We might need the back-end team involved but this is urgent for me to get rectified.
  • June 30, 2026
We hear you, ​@katev8103
We have already flagged this to the support team, however we didn’t get an update yet.
Just to double check, if you try to ask for a rep through the virtual assist, you are not given the option to start a chat with the Expert messaging or you are getting the same error that you shared above?
  • Rockstar
  • June 30, 2026
Yes, the same error message.
  • July 1, 2026
What was your expert messaging question? Maybe we can answer it here in the mean time
  • Rockstar
  • July 1, 2026
this is related to a new plan
  • July 1, 2026
Can you share more? if you do, maybe someone can offer solutions. As well, rep is available in the forum for certain issues.
Make sure you hide all personal information before sharing please.
  • Rockstar
  • July 1, 2026
It is an exclusive offer a rep provided me in the chat and needed to confirm a few more details. Not a typical Koodo plan.
  • Rockstar
  • July 2, 2026
@Flo Koodo  The agent recreated my account and I had to reregister and seemed to fix the issue.
Does not explain why initially the connection/authorization failed to the back-end so I would still like a root cause analysis for this.
Thanks,
  • July 2, 2026
They would likely be investigating still. You can probably try following up in a few days to see if a reason was found. It really depends on the root cause and how long it takes to fully troubleshoot.
  • Rockstar
  • July 16, 2026
Any update on the RCA for the issue? Still waiting to see what caused it….
  • July 16, 2026
Likely not If your issue is resolved.  Or if there is an explanation, they will likely give you a generic reason.
In my opinion,iff everything is working, I would just move on with your life
  • July 16, 2026
Hi ​@katev8103, this appears to have been an isolated issue. Although we do not have any updates to provide at this time, please let us know if you have any further issues reaching our Expert Messaging team. We're here to help!
