credit check for utilities
  • May 5, 2022 10:16 PM UTC
  • 8 replies
  • 352 views
Hi there, I just got off the phone with my gas utility provider. To waive a credit deposit, I must get a credit check. The only credit I have is my phone bill. I cannot get ahold of a Koodo service rep. How do I go about getting a credit check via my Koodo phone bill?
Best answer by Dennis
I'm Surprised your utility doesn't run a credit check on you
Allan M
  • May 5, 2022 10:58 PM UTC
You would have had a credit check done on you when you first activated with Koodo. They don’t have the ability to run one for you to give to another company though.
  • May 5, 2022 11:06 PM UTC
  • May 5, 2022 11:13 PM UTC
I’m not sure why they don’t either. We use Epcor for our electricity, and they did it for me.
  • May 6, 2022 12:54 AM UTC
I'm with Epcor as well.
Is gas with Direct energy?
  • May 6, 2022 1:03 AM UTC
No, gas is with Apex. But I think I may have figured out how to get it done!
  • May 6, 2022 3:47 AM UTC
Koodo doesn't hand you a copy of a credit check. That should just be your gas utility doing doing a check in your credit report with either Equifax or Transunion.
Kim McDonald Waterhouse
Does anyone know if Koodoo uses equifax or tansunion?
Allan M
  • Jun 15, 2022 8:23 PM UTC
Just to keep it in one place:
