concerned as i changed my number
  • Oct 22, 2025 4:28 PM UTC
  • 3 replies
  • 100 views
I changed my number and receiving calls for Mohammad the person I do not know. what kind of service it is. I notified koodo and blocked the numbers for previous owner of this number but still receiving the calls for him (Mohammed)  idk what to do.
Best answer by MilkyWay
You are likely using a recycled number and this person is trying to reach out to the previous owner of the number. You can either pick up the call and let them know or ignore it.
Alternatively, you can choose a number from a newer area code, such as 437 and 942 for Toronto and 365 for surrounding areas.
As a precaution, I would suggest you to enable the Call Control feature on your Self-Serve account to prevent any further unwanted calls. https://www.koodomobile.com/en/help/call-control
  • Oct 22, 2025 4:57 PM UTC
  • Oct 22, 2025 5:04 PM UTC
Unfortunately there isn’t anything Koodo can do for people who think the old owner still has this number. You’d have to notify whomever is calling you that it’s no longer the perosn they think it is. For automated calls or bots, you can do the call control as stated.
  • Oct 22, 2025 5:06 PM UTC
Numbers are reused.  Unless it is a brand new area code, it is highly unlikely you will get an new never been used phone number.
If you like your new phone number, you can wait it out.  Or you can change your number. Note that you won’t be able to change your rate plan during the billing cycle that you make this change; and  you won't be able to make or receive calls for 15 minutes.
https://www.koodomobile.com/en/help/changing-your-phone-number?srsltid=AfmBOopO8gRBQxaDL21GperXjc99uf-k_GqGozTW5x7IQjHAcJGFWAXn
There is also no guarantee that the new number wont have the same issue.
