cell network extremely slow 5g is dead
  • Nov 26, 2026 3:49 AM UTC
  • 3 replies
  • 19 views
The cell network is nearly dead. 5g no longer working
  • Nov 26, 2026 5:56 AM UTC
Hi
Which phone are you using, and is it slow everywhere or only in certain spots? As well, are other people around you having the same problem? I would recommend restarting and resetting the network settings of the phone to see if that can help.
  • Nov 26, 2026 5:57 AM UTC
Have you tried to restart your phone? What about removing your SIM card and inserting it into another device? Did you ask your friends and neighbours in your local area to see if they are experiencing the same issue?
  • Nov 26, 2026 2:21 PM UTC
You can check here to see if there are any outages in your area
https://www.telus.com/en/outages
