cannot connect to English Cell Phone
  • Dec 8, 2021 4:40 PM UTC
  • 9 replies
  • 2899 views
i use to be able to connect to the number, its an English cell phone number….when i call it now i get a message...1b1 the client you are trying to reach is not available…….its in a north american accent not english accent…..i can send a text to the number and she receives it. i can call all other english numbers, cell and landlines...just this one im having trouble with, i need this fixed. Her provider in England has tried everything there end so now i am trying here.
  • Dec 8, 2021 6:26 PM UTC
From a previous post, 1B1 means that the line is not active or in this case, not available.
Are you dialing a land line phone number or mobile phone number?
011 - 44 - Area Code - Land Phone Number
011 - 44 - 10 Digit Mobile Number
Allan M
So to dial a UK cell phone number yoy have to dial 011-44-7- their phone number
Is this the format that you're using?
Landlines only use 011-44-number where mobile devices use 011-44-7-number
The phone is definately active as my son can call it from his phone...i am using the correct format...i am english and use to dial this number with no problems. The texts are going through..
  • Dec 8, 2021 7:24 PM UTC
Which phone do you have?
There may be settings on the phone which may have been enabled inadvertently.
I have LG velvet
It just doesnt make sense as i call many english numbers..landlines and cells and they all work except this one
  • Dec 9, 2021 3:54 AM UTC
Try to remove her number from your contacts, have her call you, then call her back with the number from call display
Thank you for the reply...we tried and still hasnt worked.
  • Dec 9, 2021 6:05 PM UTC
Check whether Call Forwarding is enabled on your phone or not. The code 1B1 relates to a call forwarding error of some sort.
To check, tap the Phone icon, then tap the menu icon (three dots) in the upper-right corner of the screen. Select Call settings then tap Additional settings. Select Call forwarding and check that Always forward is set to Off.
If you have the Call Forwarding add-on in your self serve account (My Add-ons) you can deactivate call forwarding by dialing #21# from your phones’ dial pad (tap the phone icon to send). Place a call to the phone number in question to see if this resolves the issue.
