Can't receive incoming calls and text messages
  • Dec 22, 2023 1:33 AM UTC
  • 1437 views
Hi,
I have a problem with receiving calls and text messages from other networks. I asked my coworkers who are with Freedom, Fido, etc. to call AND text me but they said the call goes straight to voicemail. I did not receive any of their text messages either (even though they sent one).
I think this all started last week, when I went back to Koodo from Fido via a winback offer. I was originally a koodo user from 2018 until now. Took the black friday deal of Fido and ported my number there. And then back to Koodo when they called me with a winback offer.
It seems like I can call and text anybody just fine. Data is also working great (5G). I have also tried some methods that were posted here before such as:
None of these work for me. I also contacted Koodo Assists with a scheduled callback but it seems like they can’t reach me either because it goes straight to voicemail, I guess?
Thanks,
  • Dec 22, 2023 1:53 AM UTC
Did you have to port your number back in?  DId you do it on your own via self serve?
WHen you did, did you get a confirmation text from Fido?  And did you reply yes to it?
  • Dec 22, 2023 2:05 AM UTC
The agent who called me with the winback offer did the porting back of my number herself. She did so as soon as I accepted the offer. And yes, I did get the confirmation text for Fido and replied with a YES.
One thing I forgot to mention though, if this helps a bit…  is that I’m using the very sim card that I got from Koodo when I joined them back in 2018. I did not remove it when I ported to Fido because I got an e-sim from them instead of a physical one. When I ported back to Koodo last week, I removed the e-sim of Fido from my device.
  • Dec 22, 2023 2:10 AM UTC
Did you try to remove the sim and put it back in and restart the phone?
  • Dec 22, 2023 2:18 AM UTC
Yes, I've already tried that. I also tried putting it on another phone to see if it's a device issue but it has the same issue.
  • Dec 22, 2023 2:23 AM UTC
Sounds like a port issue.
Try to Call the Koodo/Telus number porting team (844) 232-7678,
  • Dec 22, 2023 2:40 PM UTC
@batista0001
We have checked and we see the transfer has been canceled. More about the transfer process can be found here https://koo.do/PortIn
We have sent you a PM with more details, please check it out when you get the chance.
