Can't access voicemail (1 doesn't work)
  • Sep 20, 2021 9:37 PM UTC
  • 3 replies
  • 559 views
When I connect to my voicemail and press 1, nothing happens, when I press it again, I get disconnected. Have the same problem in other services (Webex) that require pressing 1 to continue.
Thank you.
Best answer by Yurek
I fixed it by restarting my iPhone.
  • Rockstar
  • Sep 20, 2021 10:17 PM UTC
  • Sep 20, 2021 11:54 PM UTC
For future reference, a restart will fix most random glitches. Other options include toggling airplane mode if it’s a connection issue.
  • Rockstar
  • Sep 20, 2021 11:59 PM UTC
Thanks Goran, I’ll keep it in mind.
