Can I have 1 phone but two phone numbers?
  • Aug 21, 2021 4:46 PM UTC
  • 2 replies
  • 1353 views
Can I have 1 phone but two phone numbers? If so, how does it work? What are the costs? How do I set it up? I have an iPhone XS Max.
  • Aug 21, 2021 6:12 PM UTC
Do you want to have one phone with 2 koodo phone numbers?
Basically why you would need to do is set up an eSIM for the 2nd number.
  • Aug 22, 2021 3:58 PM UTC
That is possible if your device allows it. Some phones have dual SIM card slots, allowing you to use two different services simultaneously. Given that you have an iPhone XS Max, this means you will need to use your primary service with an eSIM and your secondary service with a physical SIM card.
To get an eSIM, you will need to visit your nearest Koodo store or authorized dealer to get a voucher to set it up. https://www.koodomobile.com/en/help/esim-and-esim-vouchers
