Call Number ID Not Showing
  • Nov 29, 2025 1:51 PM UTC
  • 2 replies
  • 217 views
Hello Community, I transferred from Freedom to Koodo and whenever I call, it does not show my ID Showing "Private Number"
Please what could be the reason for this
Best answer by Robert T
Could be your phone settings or a Koodo add-on. Check if “Call Display Restrict” is turned on in your account; removing it should fix it. Also, go into your phone’s dialer settings and make sure caller ID isn’t blocked there. If it’s still not showing, try calling *30# to re-enable caller ID.
  • Nov 29, 2025 1:59 PM UTC
  • Advisor
  • Nov 29, 2025 7:23 PM UTC
Okay I did it and it worked
