A call from (780) 970-6901
  • Sep 16, 2025 4:58 PM UTC
  • 32060 views
André Laroche
Hi,
I received a call from (780) 970-6901 offering me a new cell phone plan. Is this number connected to your company's loyalty program?
Thanks.
  • Sep 16, 2025 5:08 PM UTC
Hi ​@André Laroche
We have been unable to identify your account based on your communitty profile so we further check your account.
We recommend checking the article here to find out more about possible scam
  • Sep 16, 2025 5:47 PM UTC
That is likely a scam. I would suggest you not to pick up the call.
  • Sep 16, 2025 8:21 PM UTC
You can listen to the offer, and ask the caller to note the offer on your account while you think about it.
Then you can contact Koodo officially via callback to ask for the offer.
Never give any personal info to a cold caller.  Cold callers can also spoof official phone numbers
  • Guardian
  • Sep 16, 2025 11:47 PM UTC
This is good advice.  If the offer is real, it will be on your account when you call back in (assuming you want it).  If it’s a scam, you wasted the scammers time which gives him/her less opportunity to scam someone else.
  • Sep 17, 2025 1:45 AM UTC
It doesn’t always work with a note since normal customer rep sometimes doesn’t have access to certain promotional offer. Some promotions are only available through special channel and some even was from Telus.
