STIR/SHAKEN Feature For Mobile Devices
  • Mar 30, 2022 2:53 PM UTC
  • 0 replies
  • 1140 views
Boa_Guy Koodo
What is STIR SHAKEN?
STIR/SHAKEN is a set of network tools used to verify the true calling number. Koodo/TELUS verifies the original calling number by validating the legitimacy of the calling number and displaying a verified status on the receiver’s handset.
Notes:
  • STIR SHAKEN does not block or filter calls
  • Call Control is available if you are looking to reduce the number of SPAM calls.
How it works
With the implementation of STIR SHAKEN, a new display option (Verified) will appear on your device. Only fully Internet Protocol to Internet Protocol (IP to IP) Canadian calls can be validated on STIR/SHAKEN capable handsets. Currently, most calls are not fully IP to IP and, therefore, will continue to display as normal calls:
Description
STIR SHAKEN
Result
Eligibility requirements and conditions are met
Call verified
You will see on your device that the call is “Verified”
Eligibility requirements and conditions are not met
Call not verified/fails verification
Calls that are not verified or fail verification, will come through like a normal call, you will not see any verification status on your device (no change from how you view your incoming calls today).
Supported Devices
Refer to the table below to know which devices support STIR SHAKEN and what will the verification message display on your device:
Date
Device
Verification message displayed
March 16, 2022
LG Q70 Model LM-Q620WA
February 23, 2022
LG K61 Model LM-Q630UM
February 23, 2022
Motorola Moto G Pure
February 18, 2022
LG K41s model LM-K410WM
February 4, 2022
Samsung Galaxy A13
"Number Verified" with a green checkmark next to the phone number
January 18, 2022
Samsung Galaxy Z Flip 3
January 18, 2022
Samsung Galaxy Z Fold 3
January 12, 2022
Samsung Galaxy S21 FE 5g
November 30, 2021
Google Pixel 6 and 6 Pro
"TELUS Verified"
