Will I be charged for roaming in Niagara Falls?
  • Sep 26, 2022 10:58 PM UTC
  • 247 views
I am going to Niagara Falls Ontario this weekend and want to know if I will end up with roaming charges.
Best answer by Sophia
You might, unless you switch off roaming in your phone and also select Koodo as your network manually.
Sophia
  • Sep 27, 2022 12:11 AM UTC
  • Advisor
  • Sep 27, 2022 12:55 AM UTC
So how do I do this? Is that in my settings?
Sophia
  • Sep 27, 2022 1:11 AM UTC
Yes, what phone do you have? Try to find Connections - Mobile Networks (that’s on my Galaxy phone) and switch off Data roaming.
  • Advisor
  • Sep 27, 2022 1:36 AM UTC
I have a Galaxy A20.  I have the data roaming turned off, it says network operators is Koodo
  • Sep 27, 2022 9:27 PM UTC
Click on the Network Operators.  It is likely set to automatic and Koodo is automatically selected.   You need to turn off Automatic and manually select Koodo (it may take a few mins to search for networks.
Note this may change back to automatic after restarting or turning off your phone.
