I recently travelled from Canada. I just received my invoice from Koodo and it was massive. Upon checking I found out easy roam was activated on my account for some reason even though I never used my service for anything when I was visiting UAE and India. Easy roam was activated 4 -5 times on my account while I was in India. Is there any chance I can get this sorted? My usual bill is $64 but this time its $223. Please help
Why was my easy roam triggered without consent.
Best answer by Oliver C
Easy Roam is triggered whenever you use any of your plan features while travelling. This includes sending a text, receiving one that uses data, using data, making or receving a phone call, and most commonly when checking your voicemail. This will also trigger if you use Apple’s Live Voicemail feature.
When you check the PDF bill for the cause of the charges, what does it say the charges were for? You can also check in self serve by following the article below. When you do, does the usage make sense?
Login to the community
or
