Unexpected Easy Roam charges while roaming was turned off
  • May 9, 2026
  • 2 replies
  • 30 views
Hi, I’m currently travelling in Australia and have noticed $144 in Easy Roam charges on my account. I had data roaming turned off and did not intentionally use roaming services.
I believe the charges may have been triggered unintentionally through background network activity or automatic carrier connection. I was actively trying to avoid roaming usage.
As I’m currently overseas, I’m unable to receive a callback without risking additional roaming charges, so online support is my only option at the moment.
Would it be possible for someone to review these charges and advise whether a goodwill credit or partial waiver may be available? I’d really appreciate any help. Thank you.
Sophia
  • May 9, 2026
Oh, that is difficult to say. We are mostly fellow customers, and I don’t think the reps on here can make that kind of decision. Your best bet is to contact them through Facebook DM, if you are unable to receive a callback. Depending on a lot of factors they may or may not grant your request - good luck :)
  • May 9, 2026
Easy roam is triggered when you send any SMS, or use any talk or data with your koodo line.
In the mean time, I suggest finding out what triggered your roaming charge so you can prevent it from happening further.
