Stream+ Launching Netflix with wrong emailed
  • Feb 11, 2025 4:07 PM UTC
  • 2 replies
  • 168 views
Hi team,
Below is the my account number, Recently i have subscribed to Stream+ Basic 10$ plan, When i try to launch Netflix from Koodo it redirects me to wrong email “s****@email.com”(which doesn’t exist) instead of “s****@gmail.com”.
Also Netflix billed me again for a month apart from Koodo stream+ billing.
To fix first thing i need to check why Koodo taking me to wrong email id which doesn’t exist “s****@email.com” and then i need to talk to Netflix customer care.
Account #***39,
Wrong email: s****@email.com
Correct email: “s****@gmail.com”
Best answer by SanthoshMunibabu
Thanks, I talked to Netflix and fixed it. That's why it showing correct email id now. But anyway thanks.
  • Feb 11, 2025 4:36 PM UTC
Hi ​@SanthoshMunibabu
We have edited your post as it was containing personal information and this is a public forum.
We have looked into it and we found that your Stream+ subscription has been created with the same email you used to sign up on community here (@gmail).
We recommend checking with Netflix as the wrong email might be with them since you keep getting charged with them after you signed up for Stream+.
