Roaming charges
  • August 7, 2026
  • 1 reply
  • 26 views
Hello,
There is a $10 roaming charges on my latest bill and I was never out of the country. The date is July 7th.
Could this be removed, please ?
Thank you
Best answer by Dennis
If you login to your self serve account, you an Ask to Review a charge on your bill.  Please follow the instructions noted here
https://www.koodomobile.com/en/help/ask-us-to-review-a-charge-on-your-bill?srsltid=AfmBOoouBnOWIOWQM81uLYSv67cTYv7FEYPtBRzpyDA4EE8QJoWyuWDW
To prevent this in the future, when you are near the border, you should change your network setting from Automatic to Manual and then select Koodo.  Note that you may need to reapply the setting after a phone restart.
1 reply
  • August 7, 2026
