Roaming charge in Mexico
  • Nov 16, 2026 10:27 PM UTC
  • 2 replies
  • 43 views
Hi, I normally keep my phone off while in Mexico, but I got a notice from Revenue Canada that I couldn’t ignore.  To log into the CRA website they have to send me a text.  Unfortunately when I turned on the phone it still had mobile data turned on.  By the time I turned mobile data off, some data had got through, and I got dinged for roaming that day.  It was around the beginning of November on line ***722.
In hindsight I know I should have taken mobile data off before turning off the phone when we got here.  I am hoping someone can be lenient with me and take that charge off.  I would pull up the exact date, but now that you have 2 factor authentication it means turning the phone back on, and I don’t want to risk getting dinged for roaming again.
Thank you for your help.  Richard White
***edited by moderator → masking personal information
  • Nov 17, 2026 2:28 AM UTC
You can first submit a request on your Self-Serve account to have a rep review the roaming charges on your bill. https://www.koodomobile.com/en/help/ask-us-to-review-a-charge-on-your-bill
If that does not work, you will need to send a message to a rep on Koodo Expert Messaging to see if there is any way to waive the charges. There are no guarantees, but it is worth a try. https://Koo.do/Chat
  • Nov 17, 2026 2:57 PM UTC
Did you set up 2FA prior to leaving Canada?  If so, you can login with your back up code.
https://www.koodomobile.com/en/help/two-factor-authentication?srsltid=AYCX9vL5iDzohRnSCa5wQ6mS4x1Sm3GNOtS-5-br9qi2bVnUT6y8hYkl
