phone plan is all paid up.
  • June 24, 2026
  • 3 replies
  • 29 views
My phone plan is paid for now all I need is data.  What's the procedure
  • June 24, 2026
Hi,
Just to confirm, are you a prepaid or postpaid customer? if you would like more data, have you tried to change your plan into something else that has more data within self-serve? https://www.koodomobile.com/en/help/changing-your-rate-plan?
  • June 24, 2026
What plan do you have?  DId your plan come with data?  If so, did you turn on data on your phone?
  • June 25, 2026
Assuming it is past due, did you pay the connection fee? Have you tried restarting your phone? You may want to dial #227 to speak with the billing department.
