Phone number not working
  • June 11, 2026
  • 1 reply
  • 43 views
Hello, my phone number is not working. We had asked for a three month pause on it. I see a minus $106 credit on my account but I am not able to receive calls while dialing the phone by number  I get the error. This number cannot be completed as dialed. Please check the error and try. again  . How do I get this restarted? I need to get this done urgently, please. thanks
Best answer by Dinh
Hi
Since you mentioned “you asked for a 3 month paused”, did you ask for the phone number to be on a “seasonal hold” plan?  if that was the case, your phone number wouldn’t be able to receive or make call.
If you are back to Canada, you could log into self-serve and change your plan into a  normal plan https://www.koodomobile.com/en/help/keeping-your-account-open-when-travelling?
1 reply
  • June 11, 2026
Hi
