Partial 5G charges?
  • April 28, 2026
  • 1 reply
  • 26 views
I have 5G partial charges? roll over? what are these
1 reply
  • April 28, 2026
Did you change your plan recently? If so then you will receive a partial monthly plan charge for the service. More on partial charges is explained here: Making changes to your plan | Koodo Mobile
Regarding Rollover, does it say Rollover data? As this would be the free perk selected for the plan. Rollover data allows unused data to carry over for one month and then expires at the end of the month. From there, any unused data from the base plan is calculated and rolled over again. Pick Your Perk Plans | Koodo Mobile
