need help with adding data i
  • April 30, 2026
  • 1 reply
  • 21 views
JSMN
My billing due date is on the 30th and it is the 30th today.
I just bought more data from a local store but I am unsure if I should add it to my account now or should I wait until the 1st?
My question is, Will my data reset and go back to 0$ on the 1st even though I just bought data today? (Does data reset itself on the first if the billing due date is listed for the 30th?)
I hope I worded this right and someone responds ASAP. I really do not want all the data Ì just purchased today to go to waste if my data resets tomorrow. I don’t want to have to purchase more data
TYIA
ETA: btw Ì am a prepaid costumer *
Best answer by Allan M
When you buy a data add-on it is good for 30 days from purchase, regardless of when your base plan resets.
Your plan should reset tomorrow along with the data.
1 reply
Allan M
  • April 30, 2026
