mistaken roaming charges
  • February 24, 2026
  • 53 views
I was charged incorrectly for roaming charges.  My most recent bill shows that I was charged from travelling to the states but this is incorrect. Who do I contact to reimburse me for my bill
Best answer by MilkyWay
Let me flag a rep to help you out.
To avoid this from happening again, make sure to manually select your network to Koodo, so that your phone does not automatically connect to a nearby U.S. cellular tower. You will need to do this every time you restart your phone.
  • February 24, 2026
To confirm, were you within Canada when the charges had occurred / have you recently travelled to the states? Is this why it is incorrect?
If you can elaborate on the charges being mistaken that would help.
  • February 24, 2026
Darius Koodo
  • February 24, 2026
Hello ​@Charlie1213
We have reviewed the details and we have been able to remove the roaming charge since they were triggered due to accidental data roaming, feel free to check the details in your self serve account when you get the chance.
We recommend switching data roaming off and also switch to manual network and select Koodo, this would prevent the connection to a US tower when near the border.
For more info about how to prevent accidental roaming charges, please check out this article https://community.koodomobile.com/plans-services-232910/easy-roam-understanding-how-you-will-be-charged-while-traveling-7811296
Also, feel free to check the available  plans in your self serve account, as you might be eligible for a Canada-US plan: https://www.koodomobile.com/en/help/changing-your-rate-plan
With a Canada-US plan, there will be no fees for when the phone picks a US tower while near the border,. On top of that, you can use your phone without additional charges in US (some exceptions apply). More about Canada-US plans, you can find here https://www.koodomobile.com/en/help/traveling-with-your-canada-us-rate-plan
  • Member
  • February 24, 2026
Me too! And I went to Cuba. I'm waiting for my call from.a rep right now!
  • February 24, 2026
@LwezA do you see the roaming charges on your detailed pdf ebill?
Also OP is talking about being charged for roaming while in Canada. If you are in Cuba and charged roaming, it is likely due to data accidentally being used or a text was sent or a call made or picked up.
Can you check what triggered the easy roam charge?
https://community.koodomobile.com/plans-services-232910/why-was-i-charged-for-easy-roam-7818664
