long distance charges
  • Feb 2, 2023 5:28 AM UTC
  • 1 reply
  • 109 views
where can I look at history of phone calls
Best answer by Dinh
I assumed you are a postpaid customer?
For the previous billing cycle, you can go into your self-serve, select billing » Select subscriber » Click on View PDF and check the call history there.
For the current billing cycle, you can view your usage in the Usage section in selfserve.
1 reply
  • Feb 2, 2023 7:15 AM UTC
