Long distance charges
  • Aug 3, 2022 4:48 PM UTC
  • 161 views
I didn't use it, but it was charged. And twice. I’m so confusing. How do I solve it?
  • Aug 3, 2022 5:35 PM UTC
Could you download the pdf bill in selfserve and check the detail in it? It should have the detail of what happened. If it was a glitch, they will refund it for you.
  • Aug 3, 2022 8:50 PM UTC
Long Distance - US/International Voice Usage
Free 7:00 (MIN) Additional 19:00 (MIN) Total used 26:00 (MIN)
  • Thu Jul 7 03:06 pm 310 353-6276 CMTN GRDN CA
  • Fri Jul 8 06:39 pm 310 353-6276 CMTN GRDN CA
Allan M
  • Aug 3, 2022 9:37 PM UTC
And when you look at your phone log history on your phone you don’t see any calls at those dates and times?
  • Aug 3, 2022 9:52 PM UTC
Yes, I can’t see
Bernard Koodo
@Shushu You also received calls from that number.  Lasting several minutes which suggests calls were made and received from your device.
