Incorrect Roaming Charges
  • Nov 19, 2026 3:36 PM UTC
  • 3 replies
  • 18 views
Hello,
Please remove my roaming charges. I got charged for being in the States on my latest bill and I did not go to the States. I need it removed before I pay my bill. Thank you :)
  • Nov 19, 2026 5:42 PM UTC
If you would like a charge on your bill reviewed, this can actually be done from within your Koodo self serve. If it is just the one charge on your bill, you can login to your Koodo self serve and select the “Ask us to a review a charge”.
From there, you will be presented a quick form. Once filled out, the charge will be reviewed within four hours. Note you can only have one charge reviewed at a time. More details on this can be found here:  https://www.koodomobile.com/en/help/ask-us-to-review-a-charge-on-your-bill?
  • Member
  • Nov 19, 2026 8:27 PM UTC
This method is not working..
  • Nov 19, 2026 8:29 PM UTC
Hi ​@saynte can you elaborate, when you attempt to select the option in self-serve does it present an error or were you able to follow the process outlined in the link but did not receive a response from Koodo?
