Incorrect Roaming Charge On Bill. Please Remove.
  • Oct 17, 2026 8:31 PM UTC
  • 3 replies
  • 41 views
I have a roaming charge on my bill for Sept 26. Did not leave the country. Was by lake erie on Canada side. Put phone on airplane and still was charged. Please remove
-Patrick Buckley
Best answer by Flo Koodo
Thank you for confirming!
We have reviewed the details and we have been able to remove the roaming charges since they were triggered due to accidental data roaming, feel free to check the updated amount due your self serve account when you get the chance.
For more info about how to prevent accidental roaming charges, please check out this article https://community.koodomobile.com/plans-services-232910/easy-roam-understanding-how-you-will-be-charged-while-traveling-7811296
Also, feel free to check the available  plans in your self serve account, as you might be eligible for a Canada-US plan: https://www.koodomobile.com/en/help/changing-your-rate-plan
With a Canada-US plan, there will be no fees for when the phone picks a US tower while near the border,. On top of that, you can use your phone without additional charges in US (some exceptions apply). More about Canada-US plans, you can find here https://www.koodomobile.com/en/help/traveling-with-your-canada-us-rate-plan
  • Oct 17, 2026 8:42 PM UTC
Hi ​@Patrickbuckley1981
We have looked into and we can see there is a charge triggered on September 19, is this the one that you are referring to?
Yes my apologies I had the wrong date. Charge on Sept 19 should be removed. Thank you.
  • Oct 17, 2026 9:02 PM UTC
