I have accidental roaming charges in September ( driving near the border but never crossed ) how do I get these removed?
Incorrect Roaming charge
Best answer by Robert T
Hello there,
I’ve flagged a rep.
Going forward, I suggest you turn off roaming in your settings as well as change your carrier selection from automatic to manual and then Koodo. Keep in mind if you want to roam, this setting need to be put on Automatic again.
Just note this will have to be changed again if you reset the device but these settings should help to avoid future charges. More info can be found below. 🙂
In the meantime, you may want to upvote this idea. If there are enough votes, Koodo may consider this option in the future.
Login to the community
or
