inadvertent roaming charge- $18??
  • May 11, 2026
  • 7 replies
  • 107 views
I have an unexpected $18 roaming charge (“Easy Roam INTL”) on my latest bill. The only possible explanation I can think of is this: while at the Lisbon airport before boarding my flight back to Canada, I removed the travel SIM card I had been using (not a Koodo SIM). After reinstalling my Koodo SIM card, I briefly powered on my phone — for no more than five seconds — just to confirm it would work when I landed in Toronto. I immediately turned it off again.
It appears that this momentary connection triggered an $18 roaming charge.
I haven’t been able to reach a Koodo representative to explain the situation, so I’m using this review process in hopes of having the charge reversed.
Best answer by Dennis
@Kac1500
When you check your self serve, can you let us know what triggered the Easy Roam charges?
Please follow the article below:
  • May 11, 2026
Hi ​@TravelUser999
We have looked into it and we have been able to remove the charge since it was due to data leakage.
For more info about how to prevent unwanted roaming charges, please check out this article https://community.koodomobile.com/plans-services-232910/easy-roam-understanding-how-you-will-be-charged-while-traveling-7811296
  • May 13, 2026
I have 2 charges of roaming 1 for  1 min USA 1 for 1min mexico 34 dollars.
  • May 13, 2026
@Kac1500
  • May 13, 2026
**picture edited by moderators to hide personal information
  • May 13, 2026
Yeah that is Easy Roam triggering at 4:37pm and 9:16AM.  What triggered these?  Did you follow the instruction in the article?
Did data use trigger this or a sent SMS?
  • May 14, 2026
I would have been on an airplane  at 9  on airplane mode and still on airplane mode at 4.🤷🏻‍♀️
  • May 14, 2026
You know you could find out what triggered the roaming if you just follow the steps in the article in the link I posted above.
