I was charged for roaming by mistake
  • August 18, 2026
  • 7 replies
  • 102 views
I was not in the US, but near the ocean in BC and it said it was going to charge me and my wife $16 for roaming. Please reverse this charge.
Best answer by Mayumi
Do you see the charges on your bill yet?
The message/ roaming warning and actual charges are different.
If you see the charges on your bill, then you can submit " review the charges"
Log into your self serve > billing > support > " ask us to review a charge". They will response to you.
Mayumi
  • August 18, 2026
  • August 18, 2026
To avoid this from happening again, make sure to manually select your network to Koodo, so that your phone does not automatically connect to a nearby U.S. cellular tower. You will need to do this every time you restart your phone. https://www.koodomobile.com/en/help/understanding-how-youll-be-charged-while-travelling
@Mayumi The charges/bill has not been posted as of yet. And the “ask us to review a charge” process has not been working. First it would do nothing whenever I pressed the button so I came back again today and now it works but I get an error when trying to submit the form. Is there a support email I can reach out to instead?
@MilkyWay Do you have an iphone specific tutorial? Mine keeps toggling automatic network selection back on whenever I turn it off
  • August 24, 2026
Hi ​@chrisneilgreen
Can you please share the error you get when you try to submit a charge review?
Mayumi
  • August 24, 2026
I believe they can review once it posted on your bill. And you said now you can see it on your bill?
What error message you get?
  • August 25, 2026
Yes, you can refer to this link.
