Frustratingly Overcharged repeatedly
  • August 18, 2026
  • 2 replies
  • 95 views
I've been a Koodo customer for Over 3 Years and want to lay out a pattern that's become a serious problem, in case others are dealing with the same thing or can point me to a better path.
The core issue: I travel internationally fairly often, and every time I do, I turn off my SIM so I'm not being billed for a line I'm not using. The problem is there's no real "pause" option on postpaid – just a $15 suspension fee, or nothing at all. This has led to:
- An NSF fee (~$80) triggered because the subscription kept billing during a period I wasn't using the service at all.
- Long-distance charges around $22/minute that I was never clearly warned about in advance, and had no way to block – the call just connects and bills, instead of being stopped if it's outside my plan.
- This isn't a one-time thing. It's happened multiple times, different years, same root cause: a subscription model that charges me whether I use the line or not.
What's been most frustrating isn't just the charges themselves, but how hard it's been to get real help. Getting through to someone who can actually fix the account (not just offer a token credit) takes multiple calls, and the escalation path isn't clear from the app or website.
What I'm looking for:
1. Has anyone successfully gotten Koodo to apply call barring so out-of-plan calls simply don't connect, instead of connecting and billing?
2. Has anyone gotten recurring NSF fees reversed when the root cause was an inactive line?
3. For people who travel often — have you found Koodo prepaid, or another carrier entirely, actually solves this? I want something usage-based: charge me for what I use, don't charge me when I'm not using it, and don't let out-of-plan calls/charges happen silently.
I'd rather stay on Koodo's network if this can actually be fixed, but at this point I'm seriously evaluating prepaid options (Koodo's own prepaid, Public Mobile, Fizz) if this keeps happening. Would appreciate hearing from anyone who's navigated this successfully, or who moved on and is glad they did.
  • August 18, 2026
Koodo can block outgoing international long distance, but not calls to the US, there's no way to block the +1 country code. You can also ask a rep to remove the pay-per-use international calling add-on, though that doesn't stop US calls either. Rates vary a lot by country, you can look yours up on https://www.koodomobile.com/en/help/long-distance-calling
For the charges themselves, Ask us to review a charge in Self Serve https://www.koodomobile.com/en/help/ask-us-to-review-a-charge-on-your-bill is the path, but it only handles one charge at a time and they can only review recent bills
The only real pause on postpaid is Seasonal Hold. Turning the SIM off doesn't stop the plan from billing.
NSF fee is another issue though. Is it from the bank or Koodo? You can try to schedule a call back and ask an agent to look into it www.koodo.com/chat
  • August 18, 2026
Unfortunately, the Seasonal Hold plan can only be activated once in a 12-month period and it is only available for 6 months, where you have to resume your services. Unless you are planning to use it while abroad, it is not exactly the ideal plan for you.
Prepaid services may be an option, but you will not be able to use the service while abroad. There are currently very few pay-as-you-go services. If you want to stick with Koodo, you can consider one of the 365-day plans on Koodo Prepaid. https://www.koodomobile.com/en/prepaid-plans
With regards to the NSF fee, I would suggest you to follow up with your bank to see if you have a sufficient balance on your account. If you want to dispute the fee, you can send a message to a rep on Koodo Expert Messaging. It is worth a try, but there are no guarantees. https://Koo.do/Chat
