Charged for International data roaming when 30.day European plan was purchased
  • May 16, 2026
  • 2 replies
  • 67 views
Good afternoon
Can you check on my account as I activated my European 30 Europe travel pass plan for $60. I activated the plan from my koodomobile self service app on my phone while in England on April 15th or 16th.
I received a confirmation text saying as such. So naturally I assumed it was ok to turn on my data and roaming to use Google maps and explore the area.
Now i have a bill with $360 for Easy Roam charges from $18 daily!!
  Koodo, please correct this as I paid the Europe 30 day roaming plan.    Thanks
Seems theres alot of similar issues regarding this, and its odd.  System error and so.
Thank you.
  • May 16, 2026
As you mentioned this seems to have been an issue for others lately too. I will flag a rep for you to investigate.
Make sure you're logged into the community using your self serve credentials and they should be able to take a look. They will respond here as I have. 🙂
  • May 16, 2026
It has been solved.  Thank you
