cancel stream plus
  • Oct 23, 2026 5:15 AM UTC
  • 12 replies
  • 112 views
No button to cancel stream plus.
  • Oct 23, 2026 8:29 AM UTC
Is the Manage option showing under Self Serve > Subscriptions for Stream+, or is the whole section blank?
The cancel path is Self Serve > Subscriptions > Manage under Stream+ > Cancel my subscription: https://www.koodomobile.com/en/help/stream-plus
If the button genuinely isn't there, a rep explained on another thread that when the last Stream+ payment was unsuccessful the cancel option isn't available at that stage. After 3 unsuccessful attempts the subscription cancels on its own, and once a payment goes through the cancel option comes back.
Keep in mind Koodo reps don't have access to Stream+ itself, so the TELUS subscription support form is the route for anything they can't do in Self Serve: https://www.telus.com/en/subscription/supportform (pick TELUS Stream+)
  • Oct 23, 2026 2:23 PM UTC
I am having the same problem, was the solution found? as for the button not being there because of failed payments, that is bologna. I have never had a failed payment. but is this is what it takes to cancel then i will have to remove my cc info.
  • Oct 23, 2026 2:50 PM UTC
This seems to be a new problem that has appeared as there have been a few reports about this.
It may be a system issue or a glitch.  Let me ask my Koodo contact.
In the mean time are you looking to cancel your Stream+ subscription ​@Memawshanny ?  If so, please make sure you are logged into the community under your koodo self serve account and we can flag a rep for you
  • Oct 23, 2026 2:59 PM UTC
i want to cancel the apple+ add on. not the stream +, but that one also does not have a cancel button.
  • Oct 23, 2026 3:11 PM UTC
Let me flag a rep for you.  Please make sure you are logged into the community with your koodo self serve account.
Also I assume you mean you want to cancel AppleTV?
  • Oct 23, 2026 3:16 PM UTC
yes just the apple tv
Rox Koodo
  • Oct 23, 2026 4:47 PM UTC
Hi there, ​@johlaw . Make sure you’re logged into the community using your Koodo self-serve credentials so that we can gain some visibility over the account.
  • Oct 23, 2026 4:54 PM UTC
i am
  • Oct 23, 2026 5:06 PM UTC
so took me a while to find a phone number, but have spoken with a rep and she has cancelled. took all of five mins. vs an hour on their website trying to figure it out. so my suggestion to others having the same problem…..call a rep
  • Oct 23, 2026 6:33 PM UTC
You called Koodo?  Koodo doesnt have an incoming line to call.  They run on a callback system
  • Oct 23, 2026 10:45 PM UTC
Hi ​@Memawshanny, please let us know if you’re still having issues with cancelling, as we can try to cancel the service for you.
I’ve had this same issue. I’ve been trying to cancel my Stream+ sub on and off for a year now. None of the buttons or links exist on Self Serve anymore and the AI assist and people I’ve talked to on the phone from Koodo tell me to go to manage subs, etc. but THEY DON’T EXIST. I want to cancel this and get reimbursed and I am this close to cancelling everything and I’ve looked into blocking this payment through my debit card, but sadly, because it’s a recurring monthly charge, my bank can do jack shit.
I’ve even had multiple IT requests/cards made on my behalf by Koodo staff, but nothing has been down about it and they just keep taking my money.
Edit: I’m currently sitting in a chat with some through the Koodo Expert messaging and they said my Stream+ Basic has been successfully cancelled and that I should receive a confirmation email shortly. I’m not leaving this chat room until I get that confirmation email because it’s already been nearly 10 minutes and I’ve gotten nothing.
2nd edit: The person I was chatting with called me and said he was able to cancel my subscription on his end, which he agreed, was not always the case. Last couple people I’ve talked with about cancelling my subscription to Stream+ Basic said they weren’t able to, didn’t have permission, and the option was completely disabled on their side. That seems to not be the case anymore. So he was able to finally cancel my Stream+ Basic AND gave me a $80 reimbursement credit to my account after some discussion.
