I got charged over $100 in roaming charges for two of my lines when I had did not use any data. I purchased another e-sim card to use during my travel to avoid roaming. Can I please get a refund? Thank you.
Best answer by Oliver C
based on the images you provided you were charged easy roam for making several calls. You’re not charged easy roam for just data usage -- you’re charged if you use any of your plan features.
You will be charged Easy Roam if you make or receive a call, call and check your voicemail, send a text message, or use data. The only time you’re not charged is if you receive a text message and do not require data to do so.
More details can be found here: Understanding how you'll be charged while travelling | Koodo Mobile
