Another incorrect US Easy roam charge from July….haven’t entered US in two years
  • August 14, 2026
  • 2 replies
  • 38 views
Had another incorrect US roaming charge from July…..have not been to US in two years but live near the border in Niagara
Best answer by Koodo
Hi ​@LMB, we’ve checked the charge you mentioned and it was already adjusted by the agent you spoke with a few days ago, you can check it out in your self-serve.
To avoid future charges please make sure that the data roaming is off in your phone settings and you are manually connecting to the Koodo network.
For more details on how to prevent accidental roaming charges, you can check out this article.
  • August 14, 2026
  • August 15, 2026
It seems to be a recurring issue for you.
To avoid this from happening again, make sure to manually select your network to Koodo, so that your phone does not automatically connect to a nearby U.S. cellular tower. You will need to do this every time you restart your phone. https://www.koodomobile.com/en/help/understanding-how-youll-be-charged-while-travelling
Alternatively, you may want to consider switching to a Canada-US-Mexico plan. You may be eligible for one of these plans on your Self-Serve account. https://www.koodomobile.com/en/help/changing-your-rate-plan
