Will thr Xiaomi 14 Ultra work on Koodo's network?
  • Jul 9, 2024 7:58 PM UTC
  • 3 replies
  • 503 views
I am looking at purchasing an unlocked Xiaomi 14 Ultra but before I did, I wanted to make sure it would work on the Koodo network.
A quick search on kimovil says 2/3 of the 5G bands are compatible and 3/4 of the 4G bands are. This leads me to think it would be.
I wanted to double check whether the phone would be supported but also see if anyone has this phone and how they like it so far.
  • Jul 9, 2024 8:58 PM UTC
If you are missing bands then there is a risk for poor network coverage.
Since it is not listed on the VoLTE page, the phone may have issues connection to VoLTE.
https://www.koodomobile.com/en/help/volte
And if it cant connect to VoLTE, Koodo may charge you a $3 premium for using 3G.
https://www.koodomobile.com/en/help/explaining-koodos-3g-usage-price-increase
  • Jul 11, 2024 8:30 PM UTC
Thanks for this information. I checked the specs for the Samsung S24 Ultra to compare. There are 5G bands missing for that device but there is full 4G coverage for all the major providers. Would that mean that there may be 5G connectivity issues on that phone?
  • Jul 11, 2024 9:06 PM UTC
Telus/Koodo uses the following frequency bands:
  • 4G LTE and LTE Advanced:
    • 2100 MHz downlink and 1700 MHz uplink (AWS)
    • 1900 MHz
    • 700 MHz
    • 850 MHz
  • 3G HSPA:
    • 850 MHz and 1900 MHz (UMTS)
  • 5G:
    • 600 MHz: Band n71
    • 1.7/2.1 GHz: Band 66
    • 3.5 GHz: Band n78
    • 3.8 GHz: To Be Deployed
