Will an unlocked S23 ultra work with Koodo's 5G plan?
  • Oct 8, 2023 4:23 PM UTC
  • 414 views
Saw a brand new unlocked S23 Ultra from walmart, was wondering if it can utilise the 5G network or will it be limited to 4G and LTE?
Best answer by MilkyWay
Could not confirm with the seller but I matched the description from another website and it says model number SM-S918B.  Will it still support 5G from koodo? Thanks.
It should be supported on bands n66 and n78 for the 5G network.
  • Oct 8, 2023 5:48 PM UTC
Was it a Canadian model? That model should technically works on 5G but as it wasn't from Koodo, there's a slim chance it has other issues.
  • Oct 8, 2023 7:50 PM UTC
Im assuming it is a canadian model as it is from a canadian walmart, though it doesnt specify. It does say this "Samsung S23 Ultra 5G(vary based on your carrier and location) Dual Sim(international version) 512GB"
https://www.walmart.ca/en/ip/Samsung-Galaxy-S23-Ultra-512GB-Brand-New-Factory-Unlocked-Smartphone/3D0TYG6LNK2A
  • Oct 8, 2023 8:48 PM UTC
That is not the Canadian version. We will need the model number to figure out the bands and frequencies. Are you able to ask the seller?
  • Oct 8, 2023 10:00 PM UTC
  • Oct 8, 2023 10:15 PM UTC
