wifi calling set up s20. not recognizing my ported number
  • Jun 20, 2023 1:57 AM UTC
  • 7 replies
  • 249 views
wifi calling set up s20. not recognizing my ported number. No volte on phone. I live in a dead zone.
Best answer by Boa_Guy Koodo
Hi there @Jill Brewer   We have added the VoLTE add-on to your account, you should now be able to finish activating it.
Cheers.
  • Jun 20, 2023 2:22 AM UTC
Unfortunately, the p20 wasn't on Koodo wifi calling compatible list https://www.koodomobile.com/en/help/wifi-calling
Which plan are you on by the way? Are you a new Koodo customer or has been with Koodo for a while? Can you also check your plan and add-on area to see if you had the "volte access add-on" or not?
  • Jun 20, 2023 2:41 AM UTC
Its the Gallaxy s20  FE. Saw it on the list. But I dont see volte on my phone at all. I live in a dead zone so its a must have. I hope they can help or Im going to have to cancel 4 lines as I have family  that will be working from here  in a  few weeks
  • Jun 20, 2023 3:07 AM UTC
Oh, my bad, I thought it was the Huawei p20. Regarding the volte, have you checked your self-serve and plan add-on yet?
Anyway, I will flag a rep here as well.
  • Jun 20, 2023 3:19 AM UTC
I looked. Didnt see anything.  I appreciate your help. Tjis is bad as I am a few days away from my daughters wedding so this is not a good situation.
Boa_Guy Koodo
  • Koodo Alumni
  • Jun 20, 2023 12:37 PM UTC
Cheers.
  • Jun 20, 2023 7:52 PM UTC
Thanks for the help and getting Volte added. So does it apply to the phones that I will be also setting up?
Boa_Guy Koodo
Yes, if the phone is VoLTE compatible!
